Problem with autoradio (HDD)
Messagede KARL » Mar 27 Sep 11 11:42
Dear friends!
I am the happy owner of the car of Peugeot 308 in Belarus (Minsk).
At me the radio tape recorder is faulty, is more exact HDD a disk. :(
The given radio tape recorder is connected with the display which deduced on the monitor from above the forward panel.
There can be someone can help and write down an image HDD from the radio tape recorder or can at whom is written down separately? :?:
I would write down this image on new HDD.
Thanks.
Very much I hope that will help me at this forum.
KARL
Re: Problem with autoradio (HDD)
Messagede Adol » Mer 28 Sep 11 07:49
Hi Karl
I don't undersand exactly what is your problem.
Can you give us more information about your audio equipment ? (RT4, RD4 ? WIP, etc...)
Bye
Adol
Messagede KARL » Jeu 29 Sep 11 09:51
Here that at me only it is loaded
foto radio
KARL
Messagede Adol » Jeu 29 Sep 11 11:10
Hi
You will not find any firmware here, usually, any update is done directly by Peugeot.
May be you can try to reset your RT4 ? (by keeping pushing the "Dark" button)
Adol
Messagede KARL » Ven 30 Sep 11 07:23
Many thanks for your help.
I have made dump by button pressing "Dark" But it unfortunately hasn't helped. The radio tape recorder reboots but further doesn't want to be loaded. I think that it nevertheless is faulty HDD disk which costs in a radio tape recorder and which doesn't want to be loaded further.
Now I see a variant to take new HDD disk and to write down on it the information. As my disk doesn't work can can prompt where the information which to take written down there on a disk to write down on a new disk. Probably after that he will earn.
Thanks you once again
KARL
Messagede KARL » Sam 01 Oct 11 15:48
Jura39
I sorry, but haven't understood your question. What is init?
How to look at the software version?
Thk.
KARL
Messagede forest » Dim 02 Oct 11 10:25
1) Hi, did you try to reset your device ?
2) Have you done antything just before it crashes ?
I already hear pb like you were the device i unable to start itself by a faulty component, for example HDD, like you say.
And it's not given this little piece of software.
Messagede KARL » Lun 03 Oct 11 08:06
1) Yes, I have made dump by button pressing "Dark" But it unfortunately hasn't helped.
2) No, did nothing. Has ceased in itself to work. Loaded nothing.
I tell so about HDD a disk as when get the car a radio tape recorder highlights (Peugeot, on photo) and is audible that tries will be loaded but it is impossible. I gave HDD a disk to specialist to check up the worker it or not and they have told what not the worker, possibly problem with a boards HDD.
KARL
Messagede forest » Mar 04 Oct 11 14:43
Th peoblem is that if you change the HDD (that has a specific reference), you may won't be able to reload datas on it...
event if you copy an existing one, i think there is something linked to your car itself (through VIN, if i'm not wrong).
Messagede KARL » Mer 05 Oct 11 07:33
Dear forest,
Probably, unfortunately I of it till the end of the nobility can't.
But considering that the radio tape recorder doesn't work it is necessary to accept any actions.
What will you advise?
KARL
Messagede forest » Mer 05 Oct 11 11:03
Maybe you can try to find one on eBay with a lower price , no ? (easiest)
Because with the HDD change, you're not sure it'll work.
Messagede GR50 » Sam 15 Oct 11 08:27
hello, there are only two hard drives as possible on the RT4/RT5 Endurastar J4K30 HITACHI or TOSHIBA MK3029GAC a capacity of 30 GB IDE hard disks only strengthened and certified by Magneti Marelli for technical reasons and capable able to withstand in a vehicle, easily found in the United States.
GR50
Messagede forest » Sam 15 Oct 11 11:01
if he tries to change Hard-drives, no pb for this (as these references are true), but he must be sure that he'll be able to copy data from the old one to the new one; the only unsage point for him ;-)
Messagede KARL » Mar 18 Oct 11 10:38
GR50
Yes, there is such system. And where it is possible to find only a disk?
KARL
Messagede KARL » Mar 18 Oct 11 13:02
Now I want to find an image HDD to write down it on another HDD.
It is simple who can knows where it is possible to find this image or who can can keep itself with working HDD.
KARL
Messagede forest » Mar 18 Oct 11 13:29
I'm not sure you'll find daily users of this system that are able to make a real good copy of this system.
Maybe in the dark world where there's a lot of things, but it's not a advice, just a possible clue ;-)
I can't from my side cause i don't have this system in my car, sorry.
Don't forget to ask which HDD image format it will be (some format doesn't save all partitions info or serials)
Messagede KARL » Ven 21 Oct 11 08:26
Thanks for the answer.
I can assume that someone can has the information from the manufacturer who can give the given image HDD.
I don't think that it is any classified information.
If it is faulty HDD disk somehow not absolutely correctly to change at once all system.
KARL
Messagede forest » Lun 24 Oct 11 12:23
Sorry, i can't understand all your sentences 'give the given image'....
I won't be able to helo pyou as i don't have this device to make you any image of it.
I don't there are a lot of persons that can be able to make it, by opening their working device ;-(.
But if you want, i can ask the question in french for you, in this topic, don't hestitate;-)
Messagede KARL » Mer 26 Oct 11 19:41
If I correctly understand, you have some access to the manufacturer of Peugeot.
Can ask them this question? To technical experts. Can they can help. As in Belarus to me offer only replacement. :(
KARL
Messagede forest » Jeu 27 Oct 11 09:33
No sorry, i don't have such access, i'm a simple user...
